Bigbehr21
As usual, really good detailed photos. I am definitely cataloging all of this for when I start mine this summer. I will make every attempt to document the process as well as can be. Great job so far!
One way is to take the blade off your hack saw, put it thru the hole (bushing) re-attach to the handle and cut thru the sleeve. It will come right out then.
Looks like a great job! You mean your not going to put in a Magnum Force or Alterkation set up? haha
Looking good! I'll be tackling this job next month, I was thinking about doing the LCA bushings myself, but now I'm thinking I might take them to a professional.
Hey Hawk,
On your K frame, you might want to consider gusseting the areas where the steering gear mounts. I plan on using a "The Works" from justsuspensions.com. comes with full suspension, wildwood brakes, and brake line kit.
