Bobbie Burke
New Member
I have a 470 in my 70 Coronet that I built in 2002. It's a pretty mild build (238/244 hydraulic cam, ported 452 heads, 10:1 compression), but it needs a refresh so I was going to possibly throw in a 4.25" stroke crank and some Trick Flow heads and go for 650 hp or so. I just found the sonic check results for the block from 2002 and I'm not sure the numbers look very good based on what I've been reading. How much power/torque should this particular block be able to handle? (it's a 1971 400 block, 230 casting) Should I start scouring junkyards to find a better example or will this thing be OK?
Thanks,
-Bobbie
Thanks,
-Bobbie
