Modifications to oil passages in A727
Shade Tree Mech
7:22 AM
Minnesota
I have seen videos of trans builders indicating that the small oil passages can be opened up a bit to allow for better oil flow. Specifically, the passages for the sun gear bushings and the planetary gears. Will a minor change in these cause a reduced pressure in other needed areas? Could flow reduction in other areas be compensated for by increasing the size of the oil input holes?
The only time I ever did anything like that was when putting in a shift kit and following the instructions.
You should probably be a transmission expert to get into drilling out passages.
I never have done that except in the A-518 model (had to but a carbide drill) output shaft. Now I will say that John Cope recommended a 1/16" hole in the cooler return passage (under the governor support) to send extra lube to the sprag assy.
Mike
Mike
Would this be a new hole, or an enlargement of an existing hole? Would this be applicable to the A727?
It's a new hole, 727 shown.
Thanks for the pics. I'll do some more research. Just my luck to drill it in the wrong place. It looks like it's where the inner race bears on the case.
Yes it is new and I should have clarified in my first post that the hole is for the 727 but, may be applicable to the 518 as well as 904s.
Mike
