need a speedo gear from a 78 chrysler cordoba 904 automatic transmission that had a 360CI/v8 motor bolted to it. idk if any v8 904 transmission from other mopars with same powerplant will work or has same gear teeth count
The speedometer gear you need depends on a few more bits of information.
You need the rear tire size and the axle ratio.
Some of the cars from the 70s came with anything from a 2.2 ratio to a 3.55. HUGE difference.
