70bigblockdodge
In the shop. Two words "hot wire"
Safety
Safety
Safety
Maybe it's your wording, but it sounds like your suggesting bypassing the high limit?Without seeing a pic of what you have going on, I'm going to guess. You need to tie the black "L1" and red "limit" wires together on the back of the control. These 2 go to your power supply hot. I personally have never seen a unit that needed the red wire tied by itself to a limit switch.
You need to find where the high limit is powered and the wire coming back from the switch.
Shouldn't be too hard.
High limit goes in above the fire chamber.
But don't confuse it with the fan limit switch.
The high limit switch you drew a box around is already wired in. The new control he bought is a replacement for what he had. I will say it one more time and am then I'm out. In the box with the new control will be a red wire. Stab the one end to "limit" on the back of the control. Wirenut this red to the black "L1" wire and the black power wire. Don, you are making this way to difficult. No need to rewire anything....View attachment 1602613
Pretty sure the object highlighted here with the yellow box is your burner high limit switch.
But I can't tell where the wires go in your existing controller.
Schematic shows below in yellow.
If the wires from that switch match what I've shown below you need one connected to L1 (120V) and the other back to the limit terminal on the burner control.
Note that your existing controller controls the fan speed as well.
So if you modify the wiring you may want to consider putting it back into the original style board some day.
You can test the limit control by disabling the fan and running the unit (don't do it too long).
But the burner should kick off when the chamber gets above the high limit.
