Oil pressure loss
old guys rule
5:22 AM
Jacksonville, FL
My old brain is trying to remember The usual suspects when a motor loses oil pressure as it warms up and when it slows down
More details needed.
Obviously it drops when it gets warm as the oil thins out.
It also drops with revs as the pump is turning slower.
Could be the oil pump or the pressure relief valve.
Immediate loss of oil pressure usually means a bent push rod and a lifter that popped out of the bore.
Could be low on oil also! ruffcut
Not much info to go on.....
Could be cam bearings with low oil pressure at operating temperature when idling. These won't make a sound like main or rod bearings. Oil pressure gauge gets its signal off the cam gallery.
