BigBlock61
I tried to run coal slag through my Grizzly cabinet and it hated it. it clogged something fierce. I changed to 100 grit Aluminum Oxide and only run 50lbs and it works great.
Ditch the pick-up tube and go with a metering valve. They work much better. I made one for my HF cabinet and it works great. I also made a dust cyclone from a Home Depot bucket and some pvc fittings (videos on YouTube show how to make it). I use HF glass bead with great results too.
And led lights are a must. I have these installed in mine:
RKS 4 ft. 118-Watt Equivalent Integrated LED White Magnetic Strip Retrofit Kit 5000K (1-Pack) RKS2440-50-A - The Home Depot
DIY metering valve:
Playground sand is cheap for sure but has also been "softened." It doesn't have the cut blasting medias have. Using it equates to longer run time and compressor wear over the long term. $21 for 100 pounds vs. $7 for 50 lbs vs. New 5 hp Compressor = $megabux.
Star blast xl from dupont
I use coal slag for rust.
I use black diamond.
My local company recomended aluminum oxide blast material.
