The rocker arms are not interchangeable, they are made in pairs of right and left. Look closely to make sure they are correct, the other problem could be the spacers/hold downs did not get put back in the correct order. If the rocker arm cup is on the pushrod, it shouldn't be far off the valve stem...there can be a slight side-to-side movement. They look correct in the picture you posted earlier
As far as the squeal, maybe take a video of it happening and post it here
