What good is adding more airflow when the purpose is to optimize efficiency from idle to maybe 5000 RPM on a low compression engine? I won't disagree that the modern aluminum intakes are a much better choice for producing power but my cast iron air flow disaster runs high 12's in a 3700 lb B body. Not the fastest thing on the road but plenty fast to cause driving excitement. And if you consider performance per dollar ratio while maintaining the OP's air grabber requirement it's a combo that's hard to beat.
If it is your wish to run a stock cast iron intake there is nothing wrong with that!
But what do you leave on the table horsepower wise?
What good is adding airflow from idle to 5000 RPM?
I wonder.
How much airflow can be added at what lifts?
Let's look at some airflow tests. All flows are from the same flowbench.
Test 1) box stock big block factory 915 cast iron head 2.08" intake
Test 2) box stock 440 Source Stealth 2.14" intake
Test 3) box stock Edelbrock RPM 2.14" intake
Test 4) box stock Indy EZ Standard port 2.19" intake
Test 5) box stock Edelbrock 440 Victor 2.20" intake
Test 6) LaRoy ported factory 906 cast iron head 2.14" intake
Test 7) same as (6) but with a 2806301 stock cast iron intake and a Carter 4401S AVS carb from a 1969 383 Road Runner
Test 8) Same as (7) but swapping the 2806301 iron intake for an Edelbrock 383 Victor intake
All flows are from the same flowbench. Pay particular attention to the flows in columns (7) & (8) and the lifts at which significant changes take place.
lift.....(1).....(2).....(3).....(4).....(5).....(6).....(7).....(8)
.100...63.....66......73......66......68......71......69......69
.200..137....142....148....127....141....150....131....143
.300..187....205....209....181....204....209....172....203
.400..216....240....254....232....246....257....187....234
.500..224....255....276....272....277....292....199....259
.600..232....267....287....299....305....315....203....273
.700..236....268....292....315....324....321....204....273
.800...n/a....n/a....n/a....n/a....334.....n/a.....n/a.....n/a
Hummm.............12 cfm difference, at .200" lift, between columns (7) & (8). THIRTY-ONE cfm difference at .300" lift and SIXTY (the big six-oh) cfm more flow at .500" lift. I dont care if you are at 8:1 compression, that is going to make whopping difference from idle to 5000 RPM! And you don't even have to change your camshaft or compression to get the flow increase! But......if......you......do, think of the power increase you will have then.
But wait.........that is a single plane and you are going to lose your bottom end torque!!!
Wanna bet? Ah, add 47 cfm at .400" lift = lose torque....uh huh.
