Timing fluctuates with vacuum advance connected
General Mopar Tech Discussions
  1. RobsRR
    RobsRR Well-Known Member
    119
    17
    Dec 15, 2017
    NC
    Local Time:
    4:14 PM
    I have tried between 16 and 18 initial no advanced . I think it is around 25 with advance but would have to verify that.
    Another question. Will the advance curve change going from manifold to ported. I know the idle part would but what about after that? It should stay the same at cruise?
  2. moparedtn
    moparedtn Ed on the Ridge FBBO Gold Member
    10,710
    17644
    May 14, 2011
    On the Ridge, TN
    Local Time:
    4:14 PM
    Boy, does Professor Ehrenberg hit it out of the park in that article....but then, he always does.
    ROB - READ THAT ARTICLE.
    Ehrenberg describes your situation to a "T"!
    • Agree Agree x 1
    • RobsRR
      119
      17
      Dec 15, 2017
      NC
      Local Time:
      4:14 PM
    • 65-440
      65-440 Well-Known Member
      3,136
      2628
      Dec 2, 2009
      virginia beach, va
      Local Time:
      6:14 PM
      Yes please verify, 25 at idle is high! The again my 340 likes 22 degrees initial!....18 sounds about close to where it should be.
      So you need to drive with a vacuum gauge on the ported source on the carb and see what it does when driving....adjust your canister to that. I believe I have mine to start coming In at 8-10" vacuum....i could be wrong, it's been a while!!
      use a hand held pump to test the can, mark down how many inches it takes to start the movement and how many inches when it stops moving.
    • RobsRR
      119
      17
      Dec 15, 2017
      NC
      Local Time:
      4:14 PM
      Do you have a link to the article. You definitely peaked my interest.
    • 65-440
      3,136
      2628
      Dec 2, 2009
      virginia beach, va
      Local Time:
      6:14 PM
      As far as cruise goes should be in the 48 degrees area, all depends on your total and how much the can applies..
    • moparedtn
      10,710
      17644
      May 14, 2011
      On the Ridge, TN
      Local Time:
      4:14 PM
      As @turbine68rt has kindly provided in post #8 of this thread....
      • Thanks! Thanks! x 1
      • RobsRR
        119
        17
        Dec 15, 2017
        NC
        Local Time:
        4:14 PM
      • RobsRR
        119
        17
        Dec 15, 2017
        NC
        Local Time:
        4:14 PM
        Ok thank you
      • Chargered
        Chargered Well-Known Member
        361
        467
        Feb 12, 2012
        Peosta, IA
        Local Time:
        3:14 PM
      • 1967coronet
        1967coronet FBBO Gold Member FBBO Gold Member
        3,070
        3875
        Jun 19, 2014
        Iowa
        Local Time:
        3:14 PM
        Right now the focus is on the distributor since he's working on the timing with manifold vac.
        When he runs it with the can unhooked the timing settles down.
        Now let's forget about the distributor and can for a second.
        Put a vacuum gauge on the engine and check it for fluctuation .
        Might be fishing the wrong spot.
        • Like Like x 2
        • Bee1971
          Bee1971 Well-Known Member
          1,105
          1092
          Jun 22, 2017
          Sobieski
          Local Time:
          3:14 PM
          Correct
          Depending on Camshaft duration / lift and Carb idle settings
          Vacuum Fluctuation at idle when distributor is attached to full vacuum
          Camshaft has a lot to do with this
          Bottom line
          Vacuum reading at engine idle - Intake full vacuum
          Vacuum reading that it needs to engage your distributor vacuum canister to start movement
          Then we can go from there
          • Agree Agree x 1
          • moparedtn
            10,710
            17644
            May 14, 2011
            On the Ridge, TN
            Local Time:
            4:14 PM
            Am I reading correctly that someone has postulated that erratic timing at idle (vacuum advance
            out of the equation/disconnected) can be the direct result of simply a lumpy cam?
            I got to ponder some on that one...
          • RobsRR
            119
            17
            Dec 15, 2017
            NC
            Local Time:
            4:14 PM
            My mighty vac hand pump seems to of disappeared so I will have to buy or borrow one to check the vacuum can.
          1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
            By continuing to use this site, you are consenting to our use of cookies.
