1 Wild R/T
Through the stem, but as Greg has seen a through the stem type can be bulky for some jobs... It'll work, but bulky..
Yours looks prettier.I punched holes around the sides and front. The rearmost edge will get edge welded...Do you call those "Fillet" welds?
View attachment 1057856 View attachment 1057857
The wiggly lines represented areas to NOT punch holes. I planned to hold the patch in place with self tapping screws and those lines are where the transmission had bumps I wanted to avoid touching.
Checking fitment with and holding it down with screws.
I will pull it back off to clear off the paint so I get good welds. I'll weld through the punched holes.
This is a picture I found of another tunnel patch:
