The Beep
- 8:34 PM
- Feb 15, 2013
- Williamsburg, Ontario
Hi
This is driving me crazy. I have had the car for 15 years with a few big block motor tranny combos. Never had this before with other combos. I recently swapped in a 383 (non drilled crank used bearing etc...) to replace a blown 400 and left in the existing 4 speed in the Road Runner with 4:10 rear gears and then this started. Normal driving no issues. If I bring the revs up in a lower gear it won't do it. If I walk it up to speed, no issues either. However run it hard and once it hits 55-60 mph car starts to shake hard. I cant really tell where but it seems mid body. Feels like something is coming off! Slow down it goes away but not instantly. Press clutch same deal.
Had the drive shaft balanced, swapped wheels and tires. New motor and tranny mounts. No luck. The car is currently tucked in for the winter but I can poke at it.... Any ideas?
