Basket case
used to be deathly allergic growing up. Had to take a shot once a week (?) in case I got stung. Then when I started haunting junkyards, I got stung, and was no longer allergic. Now I hunt the little bastards.
these big bastards took over the pool area this year with about 30 or more flying in our faces. They normally dont bother people but there are so many of them we couldnt relax by the pool. Must have been 6 nests under the pool deck concrete. Wasp spray didnt affect them but rat sticky pads over the nest opening caught a bunch. Had to get an exterminator to spray the area and fog the nests. What a pain. I just killed off a yellow jacket nest under the deck...hate them all. Dawn dish soap amd water is very effective on most of them. Every september we are bombarded with paper wasps. Annoying
I like the flamethrower effect that I get with WD40 and a lighter.Useing fire can have bad results, especially around a building or a wooded area.
A wasp, hornet, yellow jacket, breathe through their skin. I've taken a soft rag or several cotton balls, soak them in lacquer thinner, gasoline or any fast evaporating cleaner and stick it in their entrance. Do it late at night when they are all home.
One thing to remember is the hornet nest has a guard dog at the hole. He'll come out at night and get you. You have to sneak up on it and be quick about placing the soaked cotton in the hole. The fumes from the solution you choose to use will suffocate them. Ground nest can be done with gas, ect. Pour a small amount in the entrance and cover with something to keep the fumes from escaping.
Another known fact, Co2 (carbon dioxide), what we breathe out, is a threat to any bee colony. When they detect it the alarms go off and they go into attact mode.
I like the flamethrower effect that I get with WD40 and a lighter.![]()
Yes, I've also used WD40 on carpenter bees. That's a cool emoji...fits perfectly!WD40 was about the only thing that worked on carpenter bees. Black Flag wouldn't faze them. I'd spray it in their hole and a couple of days later they would die.
You just like playing with fire! View attachment 817639
Now you're talking! Where do I get one?Best thing for all the little flying bastards..
Embedded media from this media site is no longer available
When I was growing up and working on my uncles' farms in south Georgia, we had to get the tobacco barns ready for hanging tobacco every season. This included burning out any yellow jacket nests (usually about the size of a double fist or bigger) that had been built inside the barns along the inside roofline, which was about 30 feet off the ground. The approved (and only) method was to tie newspaper off on the end of a tobacco stick, climb the rafters inside the barn to about 6-8 feet away from each nest, light the newspaper, and shove it into the nest before the yellow jackets jumped your ***. The trick was to get the fire to the nest before the yellow jackets smelled the smoke and came off the nest as mad as hell. If you were successful, no problem. If not, well, you were coming out of the top of the barn in record speed!I was mowing with a 4230 John Deere back in the early '80s on a low lying area that we normally couldn't get to because it was always too wet. Before I could do anything, I saw a grapefruit size hornet nest go under the axle and it came out the back of the mower in about three or four pieces.
Well all of a sudden I had hornets all over the cab of the tractor. They weren't only just on the glass but they were crawling around the edges of the glass trying to get in. I'm thinking to myself how in the world do they know I'm in here, what makes them think that I'm responsible and not the piece of equipment? Are these insects that intelligent to know the difference? Well I went over to the other side of the field for awhile and let them calm down.
Several years later I was watching a documentary on the Africanized bees and this guy was studying their habits. He was wearing a beekeepers suit, had a long piece of hose up through the suit to breathe through and about ten feet of this hose trailing behind him. He walks up to this large hive hanging in a tree and starts to handle them. They act like he's not even there. Then he removes the breathing tube from his mouth and they instantly start attacking him. It was crazy. He was proving that they are sensitive to certain chemicals and Co2 was one of them as I had mentioned in a previous post.
Watching that triggered my memory back to the day I was mowing and the hornets were trying to get into the cab. The cab was pressurized to help keep dust out and they must have been picking up on the Co2 that I and all humans breathe out. I was truly lucky that day that I wasn't on an open tractor. Worse case is if I would have had one or two of the windows propped open and I'd been stuck in there with them.
