Winter off season project engine compartment “clean up” and engine repaint.
Just a quick update, I’ve got lofty day planned for tomorrow. Motor mount swap from solids to DynaTech Mity Mounts and according to the tracking number my tranny selector shaft gasket kit should be here tomorrow. I’ve got the extraction tool, and plan on driving the new seal home with a socket. Not dropping the valve body! Other than that I’ve got a few parts primed ready for paint, then go back on the engine, and I just picked up a sand blaster for the accessory brackets, prime and paint after that. Still need to pick up a few gaskets, seal the intake bolts to stop oil from leaking into the valley plan, degrease and paint the engine, and a few other things. I’ve got enough to keep me busy for a while. As always thanks for the help, hope Christmas went well, and Happy New Year! More to come…
It sounds like you have a busy day planned! Looking forward to the update.
@donmodro just taking a second and stepping away from the work. P/S side done. D/S a bitch cause i guess when I installed the engine I put one on the motor mount bolts in backwards. Didn’t know till now as the head of the lower long bolt is hitting the oil pump. So my choices seem to r&r the oil pump or try to cut the bolt!!! Damn it!!!!
Might have had a chance to get everything done but having to remove the oil pump slowed me way down. Only had to lift the engine an inch or so. I used a 2x4 and my floor jack. Plenty sturdy. Both motor mounts are in, so tomorrow is tranny leak repair day.
We’re moving right along here @donmodro Wasn’t feeling much like lying on the cold garage floor today to do the tranny seal. Tomorrow’s another day…Now I need to add a gasket/o-ring set for the oil pump…
It’s steel and I picked up years ago at Carlisle.
I can't blame you for not wanting to be on the garage floor. My dad and I are pretty focused on getting our '74 Road Runner on the street by the spring, but after sitting for about 10yrs I am fully expecting that I'll be dealing with similar leaks.
At this point we just need the thing drivable, we can work through all of those side quests some other time.
The though had occurred to me Don, as I’ve done it before, but I’d have to secure a stand and hoist, plus I’d be afraid of beating up my paint. I just finished removing all I’m going to remove, got starter, headers, and water pump and housing out. I may pull the distributer as well.
Quick question for the group, replace the water pump, or not? No weep hold but you can see traces of a minor leak. Bearings feel firm. Maybe weak gasket or bolt backed off a bit? Should I Permatex the next gasket?
Your fender and firewall paint looks good so I gather it is just the engine and attachments you wish to clean up. I had a 1970 GTX 440 with the same paint code as yours (burnt orange as I recall). In my case I redid the marked up engine bay paint when the engine was out.
I now have a bigger problem with my 72 Charger - the guy that started the restoration actually painted the firewall and fenders with truck bedliner flat black. I hate it but would have pull the motor and either strip the bay paint or even paint over it with body colour. I expect the right way is to strip it - but with what? with paint stripper? Or is there a better way to remove the bed liner?
In your case I would be tempted to pressure wash the engine and attachments in place as the bay paint looks good. My experience with water pumps leakage is that it is usually internal - best to replace it as it will get worse.
I’ll just throw a few big pieces of cardboard down and I’ll be good to go.
Good luck with your project, it’s lots of fun, with some expletives thrown in. Keep us in the loop with your progress.
@Jam72 you’re right, my aim is to clean and touch up the block and accessories. I’ve got quite a few leaks that need fixing, otherwise it’s just an involved detail job to get the engine bay up to the standard of the rest of the car.
You should really pull the engine and strip that truck bed liner crap off. Maybe ask a local vendor who applies that stuff to see the best way to remove. May need to be removed mechanically. Good luck with your project.
The next trip out to work on mine will be in late Feb, and we have a few goals:
- Paint/assemble the dash
- Front suspension rebuild
- Brakes
- Recover front seat
- New wheels/tires
With any luck we will be at a "minimally viable" running/driving car by the time I leave after that trip, so that my dad can use it. I'll probably throw a plate/insurance on it at that point too.
Start collecting parts now if you haven’t already. They get costly ordering all at once. Seems to be the toughest part will be messing with the dash, everything else, cake.
Very solid advice. Thankfully I've been collecting the parts over the past year and a half, at this point we are mostly at the stage where we are putting it all together. Even did fresh weatherstripping and window seals.
Don’t forget to budget to get the bright work refinished after all is said and done. Nothing looks worse than shitty, pitted, and banged up trim/chrome over new paint. I see it all the time!
I'm gonna be one of those folks for a little while, with reconditioning of chrome bits following later. We will get there eventually though!
The car was pulled apart nearly 13 years ago, so at this point we are keeping the primary focus on drivable. Trim and bumpers will be cleaned up, but we figure at this point that we'd rather have those kinds of items be a winter project for a later time if doing them now means potentially missing driving the car this spring.
Managing scope creep has been a challenge for sure.
@donmodro Replaced both shaft seals, dropped pan but no dropping of the valve body. I tossed 2g. of new atf as I was constantly topping it off. Shaft was smooth, no galling, just a little discolored, so I left it alone. Linkages cleaned and reinstalled. Since they were always wet they collected alot of sand and road grime. New filter and gasket installed as well. Weather here supposed to warm here next week so hopefully I can drop it off the Quick Jack and push it out of the garage a few feet to degrease the engine and sand blast a few accessories, paint prep and spray. More to come and thanks as always for the help guys.
Thanks. I will definitely pull the engine to redo the bay properly and also retrieve the fuel pump rod which I dropped in by accident. In the past I have used a carb bracket attachment to hoist it to the garage rafters. This time I have a proper hoist unit on wheels. I expect I can again use the carb bracket but it may be better to use the hoist bolted to intake manifold bolts with leveller. Any comments re. choice between these two options?
