67coronetman
Ok guys here we go about a year ago I got a bright idea to run aluminum pulleys on my car well me not paying attention I grabbed the wrong bolts for the boys especially the one on the crankshaft where the balancer is and they were too long well I proceeded to screw those in and didn't pay attention and it crushed my timing chain cover back into my oil sling and I found this out after I started the car up and heard noise well I proceeded to remove everything in front of the motor so I can access my problem area but you know as well as I do that once you break that seal where the timing chain cover meets the oil pan after I fixed my problem it seems to be a problem area of now for me because I have a slight leak that I can't find where it's coming from up there and in the process it's blown back under my car everywhere it's not a lot of oil but over time it adds up so now it's a mess after a year I'm sure others out there have done the same thing or am I the only one that ever did this I'm probably the only one so I think personally the only way to properly fix it is to pull the motor so I can clean everything properly and put everything back on without any kind of interference to make sure and then sealed if someone out here has a better idea please let me know I've used enough sealer and stuff to try to get it to stop but its not working
