Propwash
- 3:54 PM
- Oct 29, 2009
- Island of Misfit Toys
Well.......Suspension is all stripped off. A lot of rusty old junk that took the grand tour of my garbage can.
Didn't get her put all back to together like planned, but you guys know how that goes. The old man and I at least got the New Pitman arm, Idler arm, tie rod ends and sleeves installed. Still waiting on the LCA back from the machine shop with new bushings and also my torsion bars from Just Suspension.
Strut bars were a treat to get out.. Ended up toasting the drivers side. Half of the nut was left on the threads of the bar.
No Biggie...Gave me an excuse to buy the Hotchkis Adjustable Strut Bars i've been eyeballing. They'll allow me to adjust in more postive camber for better stability at high speeds, more strength/support as well as better vertical transition/movement in the LCA's. Waiting on these also
Had some opportunity to knock out other odds and ends while the suspension is at idle...
Got the A-Pillar to cowl transition blended in. Attacked it with metal to metal, then Rage Extreme and last, Evercoat glaze. Pretty fun trying to get the sloap and then the lip for the windshield just right. All hand/block sanded out...
Aslo got the column stripped and painted. Stripped then skuffed down..tossed on a couple coats of PPG 401 Epoxy primer, and then a few coats of Wurth Satin trim paint. After a couple full coat's I went back and gave her a couple dust coats to replicate the textured look.
