What did you do to your Mopar today?
Not on my b-body, but on my '65 Formula "S" I had a power steering fluid leak and finally found it that was the high pressure hose which NAPA actually had in stock, and got it replaced today. I'm glad it was just a hose as I first thought it was the pump itself. This was a lot cheaper to fix.
Found some interior screws to finish interior up.. Need a couple more.
Installed rear seat belts in the 64 so now I can take my grandson for a ride, he's 5 so still in booster seat.
mounted 2 turbo start 16 volt batteries in the trunk of my 65 plymouth belvedere.
Took the window out of door that I replaced on the 71 RR and put it in the door currently hanging on the car.
PITA!
i 2nd that!!! worst thing i ever attempted to do on my 65 dodge 440.
look at my window in this picture, didnt work out that good that day.
Well did a little grinding on my welds. Had a time with the welder not getting grounded .This is the patch i made. Obviously not show quality but will clean up ok
this is the underside
and one of the car
I'll finish the grinding and some touch up tomorrow. Tomorrow night the motor goes back in...
installed the last front seat-tomorrow the console and tack-and if weather permitting steering wheel
Installed anew Holley 750, no leaks anywhere. Started right up, no misses, hesitation and responded well when I hit the gas. DRIVE TIME!!!!!!!!! Wouldn't you know it, here comes the rain.
Cleaning up a small block engine getting ready to paint it and hopefully use the fuel injection on it, 400 on the stand and to do/parts list started......
Finally set the motor in and bolted up the tranny. Tomorrow i should have it all hooked up. Need a radiator and new drive shaft. Still have a trunk pan to go as well
Today i put the headers on (and had to run the center link thru them). Brought the motor to tdc and got the wires on. Now i have to figure the wiring on the distributer. I need to find a 727 yoke. I may have to take a few days off. We need the shop space to pull a head off a 454. Guess the mopar will be outside for a few days. But im getting closer...
Prepped and painted my dash speaker grille, glove box door hinges, steeing column cover and ash tray - dash tomorrow.
I finally pulled the master cylinder and brake booster out. Got a new(rebuilt) set to replace them with. The set that was pulled was not originals.
put in a set of exhaust oil restrictors in my indy hemi heads .dpes it ever end!
