Everglass and All Metal
			That's interesting as I have had good luck with fiberglass filler and know of others who have as well. I have used Everglass with great results. However I have also used the metal to metal and it worked well.
Thats the name of the filler I have used before. Stuff works great.
I just couldn't remember the name..... I guess thats a sign Im getting older.....
Then I have also used All Metal. It's a very good product too. I'm glad that you were able to weld in the holes. That is the best way if you can do it.
The reason why I recommended what I did in my earlier post was because I didn't know what your skill level was and was under the impression that you were going to leave it as is.
But if you never try to do something you never know.  I'm glad things worked out for you. It can be tricky welding metal when it is very thin.
Keep up the great work!!!  Looking forward to more great posts.....
If I had to pick between the 2 products, I would use All Metal.
Either way will work just fine though. The trick is to make sure your surface is clean and rust / oil free. Try to grind down the welds until they are smooth. If you have small pinholes after grinding, go back and try to weld them up. Then smooth them down again.
If the areas are just  too stubborn and keep burning through, you can leave them, I prefer not to, (too much heat / grinding work in one area can distort the panel making it wavy), but use a small hand held sand blaster like a speedy blaster to clean out the slag from the weld area.
Then wipe the entire area down with a good cleaner / degreaser. Wear rubber gloves when you do this because oil from your skin can cause you problems later. You want to make sure the surface is a surgically clean as you can make it.
BTW , I like the color above too.
