Someotherguy
ok...is the other ecu mounting bolt tight..?
Okay the ecu is back on, I put nuts on the back so I won't strip it. So now everything is greased up amd ready to go. Still nothing... now what?
Well I'm stupid... I was going over everything again and was about to check the neutral safety and noticed I never put the wires back on it. So I tested for a ground on the nss and I can't seem to get it anymore. I put my mulitimeter on continuity buzzer function put one probe on the middle prong and the other to the frame and I can't get it to beep. It beeps if I put one prong on the nss itself and the other to the frame. So maybe it was this after all?
Okay I tried grounding the the nss tab and I just did it to the neg battery and it did nothing
Yeah I see the white connecter. In the middle of it there is a part where it looks like it melted
whats the best way to bypass them? using these? View attachment 130447
I'm surprised that nobody has asked you about the ignition switch in the steering column.
These usually do not fail immediately. I'ver seen the molded connectors get brittle and crack, allowing a loose connection. I recall reading that members have mentioned to check all of the connections. This means every place where a wire is connected to another wire by way of a clip, a plug or even some electrical tape.
I do this: I'll turn the key to the RUN position, then get out and trip the relay with a screwdriver. If it fires up and runs, I usually suspect a problem with the wiring under the dash somewhere.
You mentioned that the car has NOT been able to run since the "upgrades". There have been many times that I have done the same. You bump or move something while working on the car and don't even know it.
