Boise68
There is more on my table, or on my shop floor now
451 stroker
Last springs craigslist shopping yield was (2) 400 blocks, and (1) 440 block/crank. I sold the 69 440 block for $400 and established the one and only profit in my Mopar journey. :blob1: I kept the forged 440 crank and the best 400 block to build the above 451. The decision of 400 vs 440 stroker really came down to I already owned (low deck)TTi headers, and just a tad bit more room in the engine bay.
400 block to 451 stroker
w/440 crank and rods
440 Source Heads w/valve job, beehive springs and 10 deg locs
Comp Custom Solid cam (243/248@50; 552/553 lift; LSA 112 .016 lash)
Comp Cams Pro Magnum 1.5/1 Roller Rockers
Edelbrock Torker 383 single plane intake-Port matched to intake runners
Quick fuel HR780VS
Melling HI-Vol Oil pump
440 Source HI-Vol water pump
440 Source Aluminum Water pump housing
Comp Cams Magnum roller timing chain
FireCore Ready to Run distributor
FireCore Coil
7 Quart Milodon Road Racing Oil pan
Milodon pick up tube and Dipstick
TTI Ceramic coated headers
Mopar Performance Valve Covers and rubber grommets
Torque Converter - tbd
The opportunity to witness all 14 runs on the dyno, and be involved in the tuning was priceless. The attached dyno sheet is near the last of the pulls, this one with 1/2 inch phenolic spacer. The torque curve was broad and over 500ft lbs from 2800 to 5200. While on the dyno the engine seemed to prefer these timing settings: 15 degrees initial, with total mechanical of 34 degrees @ 2400+, and total mechanical + vac 53 degrees @ 3200 w/ 19" of vacuum. The Quickfuel HR780vs came with jets of 72, 83 for primary/secondary. The secondarys were switched to 81's for a leaner A/F.
See how big the numbers get when you scroll down. :headbang::headbang:Onward for existing engine removal.
451 stroker
Quick fuel HR780VS
FireCore Coil
