Trimming the rear quarter/roof joint because of the brazing job someone did, discovered the rear quarter was spot welded to the inner roof structure... hmmmm.
First test fit of the rear quarter panel. Lined up good except for the bottom of the trunk extension... not quite sure how to rectify this, it is off by about 3/4 of inch....Trimming the rear quarter/roof joint because of the brazing job someone did, discovered the rear quarter was spot welded to the inner roof structure... hmmmm. First test fit of the rear quarter panel. Lined up good except for the bottom of the trunk extension... not quite sure how to rectify this, it is off by about 3/4 of inch....
It could be. Once I pushed the bottom of the quarter panel in toward the trunk extension and tried to clamp it, it was much less of a gap. The clamps tightened it up real nice.View attachment 236739Tail panel was on and the tail light surround lined up really well also.... just the bottom was out of whack. Thanks Hemirunner, I will try the clamps... maybe that's all it needs![]()
