Post your 9 second or Faster combo's
This old beast went 8.70's...mainly by accident. It had much more in it.
Very cool altered, I do love them...
Seeing how this threads a little slow lately I thought I would throw this out there.32 bantam altered w/blown 392 hemi, glide, 57olds rearend. The chassis is 2x3 box rails w/straight axle front end,leaf spring and friction shocks. The rear is solid mounted w/3.63-1 gears and a spool. Rear disc brakes only and a chute. American racing magnesium wheels all around,18"12 spoke spindle mounts up front. 10x15 4window slots out back.12x30 slicks. The 392 is almost completely stock. Stock block,stock heads,stock crank. Good rods and forged pistons,about 7-1comp. This is a gas motor. Unknown cam w/ just over .400 lift at the valve. Solid lifters,stock push rods and rocker arms. Duel valve springs from Isky. Swap meet blower driven 8% over. Hilborn injection,Mallory mag. Car was built around 1970 w/426 hemi and clutchflite. We run it just for fun a few times a year. Goes 9 flat at 150. A blast to drive I dont push it. I only use the trans brake when I back up.
Sweet
I love fast cars
  • Budnicks 23 T Ford Altered 301ci Pete Jackson Injected #1 Fremont 1980.jpg
  • Budnicks 89 Camaro Z28 540ci Milodon Outlaw Pro-Stock Sears Point early 90's.jpg
  • Budnicks 92 Trans Am 540ci N20 Outlaw Pro-Stock Sac. Raceway early 90's.jpg
This is another one I play with. All steel hemi,8-71,injected on methanol. Crowerglide,3 speed lenco. Dana 60,floating axles. Learning how to set the clutch,how to drive it. Yeah,push in the clutch pedal engages the clutch. Strapped in I can hardly move. Quite an experiance.
Nice !!
That hemi was in the bantam first. It only lasted one weekend. We took it to Barona and the first pass it wentwell into the other lane. I mean it just torqued to the left. Hmmm,needed a little time to think on it. Well first thing next morning the guys yanked the motor. Didnt even tell me. I would have given it another shot. This is the only pic i have of that motor in the bantam. Oops,sideways pic! lol
572" Hemi built by me in 2006.
KB block (4.5" bore, std. everything else), Callies 4.5" stroke Magnum crank w/ 2.2" rods, 7" billet Oliver steel rods, custom Diamond pistons (11:1 comp.)
Milodon single line oiling, 440 source fab'd aluminum pan.
CNC ported MP aluminum heads done by MCH
custom Comp solid roller by Dwayne Porter (276°/284° @ .050, .672"/.651" lift) real mild lobes for street durability
Isky Red Zone lifters, Manton pushrods, DLI roller rockers
Ray Barton single 4500 manifold, 1200 cfm Pro Systems dominator
2 1/4" TTI headers, 4" exhaust w/ mufflers
727 w/ custom 9" 5k stall, 4.10 Dana, 295-65 drag radials, Cal-Tracs suspension
9.54 at 140.4 mph, all motor, and on 93 octane pump gas at 3800+ lbs.
8.95 at 149.7 mph on a very conservative nitrous pass at 3900 lbs. Still tuning.
My 63 Plymouth SS MW, just a 440 source 528 kit with 368cfm Indy SR's and roller cam. Had a 3500 vert in it for the nitrous so think that kept it in the high 9.9's naturally aspirated, with a 150 shot it ran a best of 9.23 @ 145.
Car is sitting at the moment, would like to step up to an after market block and have 900hp aspirated, might even get those drum brakes off the front :)
Barracuda looks good BOBTILE
what does she run ?
what are you running in ?
still just the NE Nostalgia stuff ?
or have you expanded your dominance ?...LOL
Nice looking & Fast/Quick Ride
My street car gets driven well over 2000 miles a year.This is the 5th season on the engine since last freshen.On pump gas @3900lbs the last 3 passes were 9.8,,,,,9.6,then a 9.5 @ 145 mph.It's a 545 mega block with STOCK iron heads
I have 5 more smaller pullies to try........
11223807_1612015082388803_5814688537689511185_n.jpg 11262106_1612016045722040_1991279657064850817_n.jpg 11698712_1612015119055466_5509924955191169491_n.jpg
This was at South Mountain Dragway last year for the Carlisle weekend.
Looks like fun Hemi-ITIS
little pulley on top big pulley on bottom = Go fast !!...LOL
My "new" 1967 Coronet.
Ladder bar, coil over, tubbed with 2 seats and some fiberglass.
Best so far is 9.72@ 136.54
Still tweaking as there's more in there...
Only have a bottom pulley so it's harder to get quicker...just sayin
Like I eluded, more to be found
I know it'll get quicker after the summer heat
But I'm still tweaking now to see how fast it'll go in the heat
Nice ride/runs actionange1
good luck Happy Moparing in the future too
