. Thinking about using some for the bottom 3ft of the wall too, tie it together a bit?That would look pretty cool, maybe have a light colored ceiling and use the roofing as a kind of wainscoting along the bottom.Well if it's terrible I'll just paint it. Thinking about using some for the bottom 3ft of the wall too, tie it together a bit?
Good thing is whoever installed the roof that the panels came from only nailed the seams meaning no extra holes.
You vent stack looks awful close to your closet flange?Finally some notable work getting done... Finally. I've got about half of the ceiling done and boy am I feeling it!!! Fighting old roofing into a 1/2" opening in F channel while supporting 10ft of it is quite the workout. It's actually nice to work with, all the sun over the years has made it very malleable to hammer out and cut.
Also found some cool tile marked down at Lowes that looks like rough sawn planks. Plus in the same picture you can see the acid stained floor I've been experimenting with.View attachment 410011 View attachment 410012
Already had a toilet on it, it's good. After looking again I think that's just a loose pipe sitting on the floor in the picture.... pretty sure.You vent stack looks awful close to your closet flange?
Optical illusionAlready had a toilet on it, it's good. After looking again I think that's just a loose pipe sitting on the floor in the picture.... pretty sure.
Pretty sure I'm doing drywall although I may do a wainscoat in the rustic metal as well. I don't know if you've seen all the pictures as I went but this is built into a bank so about half of the garage has 6ft block walls and the rest 1 coarse above the pad so if I do the wainscoat it will only be 1 wall. I'd like it all metal inside but don't really care for the way it looks.What are your plans for the side walls?
. Stopped in at Radioshack and picked up a Bluetooth transmitter so I can stream music from my phone and a Wi-Fi amplifier so hopefully I can now get Pandora with the doors closed.
