Oil pump priming tool hex size?
Malicious
4:32 AM
Melbourne
Can't find my tool at the moment and I'm trying to get up and running tomorrow.
What is the hex size of the oil pump priming tool?
Looking to see if I can whip something up that could work...
You have to pull the pump drive gear/shaft to use it, anyway. Pull it, and measure the hex end.
I made my own priming tool...hex stock, and heavy wall aluminum tubing.
Yeah it's midnight here, I probably will in the morning, but thought I'd ask so I can assess my plan of attack as soon as I get up. Eg call around, beg borrow steal, make, etc.
It's for a big block by the way but from part numbers I've looked at, they should be the same....
Made a priming tool with 3/8" steel line cut a hex wrench off and a piece of round stock and brazed it together. Cut the hex down by putting hex in a drill and used a bench grinder to cut it down to fit inside 3/8" tube.
I saw this last night before bed which is part of the reason I asked the size, turns out the hex shaft on the paint stirrer is 5/16! Perfect!
Saves me calling around looking to buy or borrow one.
See how it goes when I pull the distributor out.
LMAO, that's exactly where I got mine!
Local hardware store, about $7, half roll of electrical tape, $.39. Priming the new big block to 60 lbs - priceless
And I thought I was the only cheap one!!
Good show Chap!
Good show Chap!
You Sir are an Innovator not Cheap. Been using this innovative tool for years.
Good show Chap!
I know this thread is old but what is the tape for? I haven't pulled my distributor yet but getting ready to.
That's why I used 3/8" tube post #5. I have a mopar performance hex priming tool. It's hardened hex stock, can nick bushing if your not careful.
