Do you have all your front suspension bushings ect?
Yep, all done there., except for getting some kind of 90/10 shocks later.Do you have all your front suspension bushings ect?
Thanks Doug, I've come a long way with a lot of help from great guys like you on this site. What kind and color of hammertone paint did you use?Looks great. You've come a long way. The hammertone on the cage works great we've done several, even with the foam brush. Touches up easy as well.
That is a good idea. I've often worried that my fit was very poor until I saw others. I've been thinking of doing something similar.After quite a few tests with different paints and coatings for the trunk that weren't what I wanted I finally found something that work very good. Not really the color/s I wanted but, believe it or not it is the stuff they advertise on tv with that annoying guy, Flex-seal., lol.. I did the insides of the quarters and around the edges but not so much on the floor. If you spray it lightly it makes a textured surface/finish. I also may have come up with a good fix for something that has bugged me. The gap in the sides of the trunk floor where the floor extensions drop down and connect to the quarter, made me worry about dropping stuff/tools/parts down there. I sliced a piece of a/c line insulator/armaflex and it then fit in the gap perfect enough to keep stuff out and it has a sticky strip to stay in place. May spray a little of the flex-seal over it also.
View attachment 430484 View attachment 430505
Lol, not to worry, the gap is normal, every mopar b body I've owned had about 1" gaps there from the factory. If you close the gap up like I did or similar, be sure not to seal it airtight, I'm thinking if it was sealed tight it might hold moisture there.That is a good idea. I've often worried that my fit was very poor until I saw others. I've been thinking of doing something similar.
Money came out of mine when I cut out the quarters. 52 cents!Looking good, I have to agree blocking off those extensions are a must... crap collectors!
Lucky you, mine was full of sand, dirt, wrappers, toys and rust thanks to all the crap holding moisture lol. Somethings make you wonder about the R&D where a simple piece of foam or sheetmetal could save it from premature rust.Money came out of mine when I cut out the quarters. 52 cents!
David
