Bruzilla
Had to replace the quarter window weather stripping, replace the hood bumpers, replaced the sway bar links on the rear, and the console door lock broke and had to fix that.
			tarted mineI put a new power steering pump in the '71 Charger. Unfortunately, I dropped it and bent the pulley. So, $100 later, I have a new pulley to install on the new pump.
What is this vinegar you speak of?Went out to the shop for the first time in a week and knocked the distributor bushing out of the block. While I was at it I fished an old soft plug out of the blocks cooling passage that fell inside when I tryed to remove it. So the block is ready for the machine shop, but unfortunately, my wallet isn't. I fished the crank pulley and a collection of formerly rusty bolts out of a vingar bath I started for them two weeks ago. They came out almost a hundred percent. So I wire brushed the paint residue off the pulley and put it back into some fresh vinegar. Took the used power steering pump I bought appart, to de-rust the pulley and reservoir. The assembly was the hardest one I ever took apart. I dented the small flange on the outside of the reservoir which is repairable. However there is a fair sized dent, that was hidden by the mounting bracket. I'm thinking about picking up some dry ice to see if it will shrink to a decent looking size. Removing the pulley proved to be a bugger. I had trouble keeping the little ram, at the bottom of the large bolt in the puller assembly centered. It kept walking as I tightened it onto the pulley hub. I dug a half by quarter inch up a bolt, and set it insde the threaded portion of the pump shaft. It allowed the puller (Snap-on) to start pulling the pulley off. However, I broke a half inch socket while turning a large three-quarter ratchet. Replace it with an impact socket, but once the ram contacted the hub of the pulley again, I had to tap it back to center with a drift and hammer. All the way off the pulley protested with loud cracking sounds as the pulley came off the shaft hard. Luckily no damage. I put the parts from the pump assembly in the vinegar to clean them. Later I will take the pump apart to inspect it,and hopefully, it's serviceable.
"White vinegar" (only) is three percent acidic and it will eat rust if a rusty part is soaked in it long enough. It will remove paint too. I buy it in two-gallon jugs it's relatively cheap and safe to use.What is this vinegar you speak of?
