FYI, you need to manually turn the motor over with a breaker bar & socket while you run the drill to get the oil holes to line up & pump oil into the rockers.
Doug could be right, if you don't see any external leaks(especially by bellhousing) you could've dropped a gallery plug by the front of cam sprocket.If oil pours out at the filter chances are the pick up and pump are ok. My bet is that if it sounded ok that it could missing an internal galley plug.
