- 12:07 PM
- Mar 10, 2010
- Hanover, Pennslyvania
1962 Dodge Original Push Button Torqueflight
Spent the last couple of weeks getting this car off the jack stands, pushed it outside today, hoping to try out the trans and running gear and nothing!
Here I am trying "drive" to "reverse" to "neutral" back to "drive" ect. Nothing, not even a grunt!
Here's the history:
1.)Had the trans rebuilt by a reputable shop.
2.)The shop had a torque converter company who knew how to tweak a 19 spline TC for a little higher stall so that's what I got.
3.)TC was installed correctly, even had a bracket on it to keep it from backing out. When bolting to the flex plate, it spun freely and had to pull it toward the flex plate.
4.)During the 20 min. engine break-in, added 7 quarts of fluid. Fluid level was 3 to 4 inches up on the dip stick and this has never changed. Even checked it today and it's still up on the stick. I did the engine break-in in "Neutral" without it being in "Park". Also the car didn't have the driveshaft installed.
5.)During the engine break-in I did notice the speedometer running up to 20 mph several times? Not constant.
6.)Shift Cable was installed correctly and checked the detent engagement for the safety switch. Seems to work perfectly.
7.)Set the trans linkage to carburator per the FSM.
"Wide open throttle, trans leaver all the way back."
8.) Forgot to add, I had them upgrade to the newer pan with newer style filter. (Hope he installed that right)
I don't know if there is something stuck, not allowing the fluid to go through the TC or what. I've been concerned about the high dipstick level and figured after installing the driveshaft and having a load on it, it would circulate and the level would come down, probably having to add more.
Let the "Spit Balling" commence!
Here's the history:
