themechanic
Oklahoma is OK
- 12:16 AM
- Nov 11, 2012
- Moore, Oklahoma
My other consideration is should I place tape over the painted surface and drill outside in or the other way around?
Stacey David has a quick tip for drilling through painted panels.My other consideration is should I place tape over the painted surface and drill outside in or the other way around?
Yeah, deffo use tape, I would drill in gently.My other consideration is should I place tape over the painted surface and drill outside in or the other way around?
I would rather use speed nuts....The thought of popping those on gives me chills....
Oh my goodness. The plastic is what holds the emblems on! You drill the hole, slide the plastic through, and then push the flared area in and that locks the emblem in place. You take that off and you may need to thread those posts.I called Jegs and Mopar Performance and they had no installation instructions and both said the white plastic on the studs "probably" comes off and the emblems are installed like the original ones from the factory with speed nuts. The MP guy said the only thing in his data base said these were manufactured to the original specifications using the same materials as the factory emblems.
I may have to heat these a bit in order to slide the plastic off the studs.
