- 6:32 PM
- Mar 10, 2010
- Hanover, Pennslyvania
Fired up the 440 today and I'm just going over different things. This engine has the cam broke in but hasn't seen any asphalt yet. Oil pressure is 40 lbs at idle and off idle will go to 80 lbs. I thought I would pull the valve cover fill cap and see what kind of oil I am getting to the rockers.
I'm thinking it should be more of a cascade of oil taking place but the video will show what I'm seeing. Increasing the rpms doesn't make much difference.
Hydraulic lifters, .020 preload. Summit 6401 cam.
Solid pushrod
Yes the shaft holes are down and out.
Crane adjustable rockers
Solid pushrod
