Paul_G
- 7:45 AM
- Dec 24, 2013
- Surprise, Arizona
Sounds like the people who went with efi/tbi don’t know how to tune a carb, better yet, drive a car with a carb.....(it a joke guys) 30,000 miles with the bee with Holley DP mechanical secondaries with no choke in three years, from -10 degrees to 90 degrees, up and down in valleys and hills, no problem????
You are pretty much right on that.
Tuning a carb is a skill that must be learned. It is accomplished by turning bolts and changing numerous small parts and gaskets and leaks and fuel where it shouldnt be and on and on.
You must use the same basic rules of air and fuel ratios, but you make adjustments with a small hand held programer, which used to require a full on computer but not anymore, to achieve the changes you want to make in various tuning parameters. Including tuning the ignition.
I am talking myself more and more in to switch over guys.
