Fuel starvation issue?
Maybe someone can measure one to establish what a normal one is ?
I will be doing before and after measurements. I’ll post them up. I am curious to see how worn out mine is. I also need to record it in case I need to troubleshoot later.
WOW! Now that is a scary sight! A worn pump rod like that would make me start wondering about lubrication.
No worries, the camshaft is good, so are all tappets.
Even de camshaft lobe for the pump rod is not damaged, last time i checked some marks were there but should survive.
If lubrication was that bad due to oil quality or so everything would have run to the ground already.
Most likely a cheap repo, i installed a NOS rod.
Looks like I found a culprit. The old one measures in at 3.024”. A little short. Story of my life. LOL
That is almost a quarter inch short.
Mine measured 2.967" when i removed it.
For sure that push rod caused issues!
What new rod did you buy?
I got the Howard push rod recommended (Part number 92152) but best (they say) is NOS as they are properly hardened and survive longest.
I took a measurement prior to installing of the length, note it down and drive the car for 50-100 miles and check again.
If it has worn again a quite substantial amount there is either more damage, or the push rod is not hard enough.
Keep checking Ebay or so for a NOS push rod, good to have in stock :)
Edit: I've said this before, just replace it on a yearly basis if wear is found, can't go wrong for $20-25.
I likely will get a spare. Kinda like a ballast resistor when they go, they go.
Hey, Your welcome for the insight! Glad you figured it out!
It was definitely the rod. Installed the new one. Ops check good. Big difference in lengths. Thanks for the advice!
Yes, but first he would have to thank wagonman in post #2, then Kern Dog in post #5 before he thanked you in post #10. Sorry, but you were a little late to the party with your suggestion.
Gee, I hope you don't think that I'm picking on you. That would be unbearable...
Now why the hell would you want to do that?
That’s what stumped me.. I had 6psi at the carb when cold. Zero and starved out while coming up the hill to my house. All the checks I have done have shown normal when on level ground at no load.
Same for me (starts at 5 psi then drops as engine is hot to close to 0 on the gauge) but thought from something I read that the liquid filled fuel pressure gauges will not show accurate pressure as temperatures change.
