What did you do to your Mopar today?
Replaced the exhaust pipes on the 1955 Plymouth Plaza Suburban with some NOS pieces I found.
traded the 06 daytona for a 98 24 valve cummins. .. still keeping old blue tho. ....
Started working on a Power Master alternator installation. I’m also changing the old points type voltage regulator to the newer transistorized style. I’ll do the bulkhead/ammeter bypass as well. Once finished with that, I’ll put the MSD 6AL box and coil on it.
Put in some Hi-Test, found a quiet Ocala country road and BURNED SOME RUBBER!!!!!!!!!
What the hell, needed new tires anyway. Now I got an excuse to get em, heh, heh.
the next assorted batch of junk that will get primed with dp50 in the next day or 2
some of these parts like the floor pans and 4 speed tunnel are for other future projects
besides the 2 we are currently working on.
with all the junk we have,i always have something around to strip and prime,it is almost never ending..lol
i like to do things in small batches as where we are we try to fly under the radar
it will be nice to have some stuff all ready to go ahead of time down the road.
Started to bolt the exhaust pipes to manifolds on the 65' Satellite. Couldn't get the garage below 92degrees. Said - Screw this. And went back in the house.
Installed plug wires & dripped sweat on pretty much
I hear ya. I started to install plug wires but all i did was drip sweat on everything.
Drove it 60 miles to try to find someone to paint it that doesn't start pricing at 5K.
I've got about 5K total in the car!
Found a guy advertising on CL that will do it for 2300.
Stumbled into this on the way back. Location noted.
What I did for my mopar yesterday. Waited along time to pave rear garage.
Before and After.
all parts primed up and most of it already stuffed away into the rafters
except for the Bee parts
it had to be sprayed in the early morning as it has been just too hot in the middle of the day to do much around here.
up next is another 71 header panel for a future project
a pair of doors i have been pecking away at and plenty of block sanding on the Bee in between..
what i'm trying to do is get most of the bolt on's done on the next few projects before beating on the shell
that way when i get there
i can slap it together rather quickly
i have too many things all ready to go..
i wish i could do this every day but
you can see what i spend a lot of my free time on..lol
OUCH !! that cost ya! Probably won't crack before this Winter, but when it does, be sure to seal up cracks before water-ice gets in them ...the death of asphalt...........................MO
