- 10:30 PM
- Oct 16, 2013
- Kiel Germany (back again)
Much appreciated, thanks for that.
I did get a tail light harness from M&H that does have the connection up to the dash area. I bought these some time ago and I would have to look up how much it was. They are expensive but they look factory original and I am satisfied with them. The harnesses were on back order until they produced another batch but I ordered early and wasn't held up.I had to buy a new mirror for $80 from Y.O. Mine was pretty shot. Be careful when installing, I only had the 2 of the 3 screws to put in before the headliner and almost poked a hole in the wrong spot because I had the base backwards at first...duh.. I wonder if I can get the wire harness from the dash back to the tail lights from M&H?, mine is a little tired.
Your right! I have been distracted with the Citabria. We got it together and have been taxi testing it. We are excited to fly it but we can not fly it yet until it is approved by the FAA so maybe I will start spending some time on my car.What's your status bro? We need an update.. I bet you're riding by now, and having so much fun you just can't take the time out? Or flying?
That is too cool!!!Your right! I have been distracted with the Citabria. We got it together and have been taxi testing it. We are excited to fly it but we can not fly it yet until it is approved by the FAA so maybe I will start spending some time on my car.
Thanks, I will plan on getting one.Really looks good! We'll need video of that 1st flight.
Thanks Kid,I think I may have it figured out.. Fortunately my original under dash wiring was ok and so much is not going to get hooked back up and I haven't finalized where I'm going to stow it all yet, and it's all labeled... So here are my findings, the possible reason you don't find it is because it comes from the fuse box, 2 wires that divide to 4 going to console lights, and 2 going to back up light switch. , or at least that's the way mine appears to be. Hope that helps, let me know if I'm right or not. Here's a couple of pics, let me know if you need more.
Kid, I have been trying to research the information that you gave me. I have been trying to study the pictures that you sent. I think that I might have figured out my problem. There is another harness that plugs into the inside console harness and runs under the carpet to the driver side kick panel. This one connects to the reverse light switch wires in the under dash harness, and splices into the door jamb switches(YELLOW).I think I may have it figured out.. Fortunately my original under dash wiring was ok and so much is not going to get hooked back up and I haven't finalized where I'm going to stow it all yet, and it's all labeled... So here are my findings, the possible reason you don't find it is because it comes from the fuse box, 2 wires that divide to 4 going to console lights, and 2 going to back up light switch. , or at least that's the way mine appears to be. Hope that helps, let me know if I'm right or not. Here's a couple of pics, let me know if you need more.
Thank you for the description. If I have to I may try and use all of the information and make my own. For now I am going to try to see if I can find one to buy. So far I have not found one that is reproduced. I would even be happy to find an old messed up one that I could use the plugs and copy.I may be confrused about the way it lays out in the car, and more, but those pics above of mine show the pink and orange coming off the fuse box. As you can see they are black taped up together to one, and on the end of it is the black female square 4 wire connector (the black plastic outer part is male but the 4 spade connectors in it are female so the manual calls it a female, I think). There is also the 2 wire black "male" backup plug. The crude drawing below shows the colors of that 4 wire plug, the 2 wire backup connector, and the 4 wire white male console harness plug. The 4 wire plugs fit perfectly together. And all this seems to match the book except where the white wire changes to a violet with white tracer at that connection, my book (which must be wrong) shows just violet but it does change back to white at the shifter switch. I thought my yellow door jam wires were originally in the bundle of console harness but I did remove part of them from somewhere around there because they were damaged and I'm not using door jam switches anyway, or console lighting, and probably not the backup stuff either, for now anyway. This is the way it all came out of my car I think, and it was all fairly unmolested. Am I wrong about the 4 wire plugs connecting to each other? What happened to your friend? I was hoping he could finger it out. Disregard the pink marking, that was from something else.
View attachment 692829 View attachment 692830
Thank you,Here is what the back-up (violet and white) connector looks like and I found where it plugs to the main dash harness right before the firewall/bulkhead connector.
View attachment 693915 View attachment 693919
