JB400
69 Charger
Looks like fun.
Does anyone have an example of a 4-speed backup light harness that routes from the bulkhead connector across the bell housing and along the A833 to the BU light switch? I'm looking for an overall length? Also, does anyone sell a BU light switch pigtail?
thanks
Brian
If you are installing a console, the wires will run along the drivers door, under the seat to the center hump, at that point there is a ground screw to the floor pan and then up to the console. The back up light wiring plugs into the the console wiring harness.
Appreciate the input. I am not running a console however I am familiar with the automatic console wiring as I have a complete setup for an auto.
In my case, with a 4-speed, the BU light switch wiring goes thru the bulkhead connector. The auto column shift has a similar setup (I think depending on the year) where the BU light / NS switch is on the transmission.
So anyhow I'm looking for the length of the BU light harness on the engine side of the firewall that runs from the bulkhead connector down to the BU switch in the tranny.
thanks
Brian
propane torch and a wire brush, eazy peazy.... where 1/4 meets the rocker too
