HYRDGOON
- 9:09 AM
- Apr 20, 2013
- Breslau, Ontario, Canada
So another unexpected expense but want to do things right so here goes.
The guides in my Stealths are shot. I'm not putting over $600 into $900 heads I'd rather put the money into better heads so for those that are familiar with boosted applications what would you recommend for heads?
522 cubes F1R procharger not going over 15lbs boost.
Cam specs:
23-000-9. 13083B/3039B. 238/248 duration@.050, .545/.543 lift (1.5 rocker ratio), 115LSA +4 degrees of advance.
The Stealths were 80CC at 10:1 I'm also looking to run at about 9:1 so taking that into consideration now too
Cam specs:
		 .  By the way, Brian is dead set on using Trick Flow 240's on my motor.  He says they are by far the best bang for the buck.
