What did you do to your Mopar today?
Yesterday was my 'Cuda's 52nd birthday.....I had to work all day but this morning I took her out on a play date!!!!
Instead of another same old pic, here's different kind of view only lovers of old Mopars will enjoy!
Jeff
I need one of those. We got rid of them years ago, now I need one again. Hard to hold a drink with a 4-speed.
Re-installed the wheel arch moldings. I bought new ones but when I pulled them out of the box I noticed each one only had 2 holes at the top pre-drilled for mounting leaving me to drill the rest. I cleaned up the old ones and re-installed them, instead.
Glued my vinyl top on
E319FD5E-0028-4CD5-ACE4-7E02F4DB5C63.jpeg 7C3F1F5F-9363-4353-9C0D-56B0B7F24201.jpeg 7020C83E-78DE-48E2-810F-393AA520F73D.jpeg 227B5743-E7BE-4952-AE0C-684726897991.jpeg A291E8C2-F535-4B6D-AE61-2B2BE8E3D811.jpeg 7C1B75C3-230C-47A5-9CE4-F7E52C371841.jpeg 9558B395-51AB-4BF1-93C5-F4B35FC1F26B.jpeg
I always forget to take pictures but the tops of my door panels were black from sun fading. Should be gold. I found some Rustoleim gold metallic paint that I used to pain my steering wheel and it matches dam near perfect. You have to be standing right over it to notice. So I am happy.
Today, I had to change the camshaft position sensor in the '04 Neon R/T. I'd love to meet the engineer who designed that sensor to have metal pipes directly in line with the bolts. What a PITA.
I also played with the idle mixture screws on the Edelbrock in the '71 Charger. I found it funny that Edelbrock's instructions expressly stated to adjust the idle mixture with the air cleaner on. However, I don't have that kind of dexterity. I tried a shortcut of hooking up a vacuum gauge and adjusting them for maximum idle vacuum. At about half a turn out on each, I got a maximum vacuum reading of 16.5 inches and called it good.
