- 4:25 PM
- Dec 14, 2008
- Long Island,New York
There may be some races where I would be more competitive in a "street legal/DOT class" vs an outright slick, but I hear ya...If you want dedicated track tires then use slicks.
I happen to have a subscription to Power Nation, so I just watched the part on them back halfing the A body...
---Your feed & return go into the rail,are they run through the rail or go through and run the outside of the rail?
Looks like one going to each rail,did you put rubber hose around the line or does it just lay in there.Mine runs outside the rail.---
HemiItis I think you're asking about my fuel line? I don't have a return, just deadheading. But yes the fuel line runs through the frame rail, through the frame connector tube and out of the frame at the torsion bar crossmember.
---Looks like one going to each rail,did you put rubber hose around the line or does it just lay in there.Mine runs outside the rail.
My knowledge comes from being a GM dealer tech. Spent over 20 years doing frames and suspension. The heim style upper arm will allow additional adjustment to allow it to come into spec. Though there are some items that could be bent causing it to drive poorly. If the toe and camber are in spec it wont wear tires. Pretty easy to check for bent items. This is the 9.55@142 Cal Track car
DougView attachment 869751
I'm convinced from function that my rear factory leaf springs are worn.I've been amazed at what stock parts are capable of!
Oh, absolutely! I was talking about frontend.I'm convinced from function that my rear factory leaf springs are worn.
When faced with choices, with the help of forum membersI decided Caltracs were my best option.
Well given the problems I've had, and it may have something to do with the K-member, although I don't know, or whatever damage occurred that has the passenger front a little wacky on fit and finish, and the cost of a used junkyard lower control arm from Stephens Performance, I am absolutely confident and satisfied with going all new QA1 w/SPC UCAs. Now as soon as my 6 piston all around Wilwood disc brakes come in, and because of a recommendation on the forum all new stainless steel brake lines from Inline Tube, I will go from looking at parts in a box to seeing what all those parts feel like to drive. The Borgeson power steering box will likely be part of the install too, if I can get the Wraptor installed between now and then.I was talking about frontend.
I really like being able to put such surprisingly wide tires on these 9" Year One aluminum Rallye wheels, with everything else stock...315/35/17
INFLATED OVERALL DIAMETER (IN.)25.6 INFLATED OVERALL WIDTH (IN.)12.6
View attachment 867422 View attachment 867424
But I have to say, I love the look of big FATTIES on a B-Body!
View attachment 867426 View attachment 867427 View attachment 867428
Oh YEAH!!![]()
[/QUOTHERENA
Here are my big tires on my B-body 64 Belvedere
