- 5:29 PM
- Jul 17, 2008
- South Jersey USA
it is also possible that only the upper portion is over....... will be watching for updates
Maybe both rails, inners, and core support as a unit, just cut everything that's bent off......... the hood and fenders, will dictate everything..... this is still an option.
I am tempted to just slip THIS in:
Fender aprons, rails, core support all intact. Fewer welds to complete the repair, fewer chances to screw things up.
The downside? I'd then be without THIS stub if I ever needed it for my red car if I wrecked it. I'd sure feel better if I had another 66-70 front stub or a parts car with it intact.
Thank you for the response.You need to pull the frame on that car, its too far out for shims or elongated holes.
You can rig up a come-along or a cherry picker to make a pull.
Check this out.
Used to do plywood decking and 1x4 strip decking (when we could still do cedar shingles) and used a framing hammer to drive 6's and 8's. Set the nail and one hit home but every now and then, I'd scrape a finger with that cleated bastid so I ground them smooth along the edge of the head. Bingo! Didn't work in home construction nearly that long but drove a lot of nails. Still have the framing hammer. Also used a decent size hammer hatchet to chop the ends of the ceiling joists since the framers were too lazy to cut them and would use it to lay down the first sheet of plywood or a few rows of 1x4 then come down and stand up enough material to do at least half the house or until I got hungry. Still have the hatchet too but it's seen better days....I have flattened numerous hammer faces over the 32 years in construction. I don't recall any of them being hardened. I have used Titanium hammers since 2001 and have to reface them every couple of months. The grid pattern wears fast.
I hope to get the car in my shop in the next couple of days and start removing the bent stuff. I'll certainly go back and REread some of the advice I've received in this thread.
I've done way too much stuff like that. Gave my nephew a couple of sets when he opened up an automotive shop but he wasn't too good at running a business and closed the doors after about a year, so got the stands back.Now I get to come up with a way to get it in the car and supported! I might enlist the help of a couple of car guys that I know. I'll need a few more jackstands. I gave 4 away when I bought the car lift, thinking I'd not need them again.
