 - 8:06 PM
 - Apr 13, 2012
 - Granite Bay CA
Thank you. I did plan to use some self tapping screws that I got from work. The flanges on the frame rails will get screwed to the torsion bar crossmember. That area should not require any adjustment since I am putting them in exactly the same distance off of the rocker panels as my red car and as the Belvedere was. I see that there is plenty of room for error up top at the cowl area though. Too high and the fender gap at the rocker is too wide. Too low and the fender will overlap the rocker.
This picture was before doing any work. Look at how the door to fender gap changes from top to bottom. The gap at the rocker was over an inch! The core support was high and the cowl was low.
This is getting interesting!
