My 68’ Rustic Charger Resto
It’s been a little while since I’ve posted but, I’ve made some slow progress. I had to put a new heat pump system in the house and a few other things (You all know how that goes! LOL).
Next I cleaned up the inside of the torsion bar cross member. The crossmember is in pretty decent shape aside from the frame rail brackets inside. I removed the brackets and made some replacements out of 2” box steel and some angle welded together. Then I sprayed everything in copper weld through primer and welded everything together. Think it should work out fine and is probably stronger than the factory braces.
3E1CDF93-858E-4E0F-8A77-269C7E010648.jpeg 6465BAB8-AA57-4BB5-9500-ECBDEC23A2E4.jpeg 07CED762-5B9D-499E-9497-7D8309C5AC66.jpeg 5E192643-1886-4673-8649-B72BBA6354F8.jpeg EC4546DC-72B3-41D7-B45C-280821892AA9.jpeg 16B8EBD3-58BF-402E-B3CB-EA8E87B4FB29.jpeg 363E98B8-B274-4FC5-B6FF-5488314A63F2.jpeg CF40FA52-5A73-4197-B874-08C7CF819EC6.jpeg 7D1F5212-27E5-4359-AA51-C845944830F7.jpeg A31BE122-D67C-4FB7-8511-B7222DD72200.jpeg
After seeing signs of rust from the cowl corners and from the lower cowl vents, I figured I should pull the upper cowl to inspect the damage. After half a million spot welds, this is what I found. Luckily the donor coronet I bought has a really clean upper and lower cowl to spare.
BB1766DF-F29C-442B-BCB2-CC5CE3497B16.jpeg 93788BC7-87BF-4652-95FB-7886C9906751.jpeg 8461E6C7-59E7-4342-B35F-9F074A0C2B94.jpeg 8F11C638-1812-4A96-AE33-4D6D44437F1E.jpeg DAECF9ED-31AF-4A59-839A-794880C7C5F2.jpeg A274EB7C-52B3-45EB-8A6D-2EADFB477ADF.jpeg 6EA52B67-FCA2-4143-B7BD-CE6786AEE679.jpeg 6DE499C8-7B74-4EA0-9BF5-747CD7599669.jpeg E3FCABBA-C645-4B28-8CA4-546BA5A9571D.jpeg 980AAFCA-DF61-468E-AB3F-B8F4E6CE77F3.jpeg
Pulled the upper and lower cowl off of the coronet and blasted them at my buddy’s show (Thanks Dave!). Only bad spots were on the driver very side cowl vent ring. Got to try out this shrinker and stretcher kit from Eastwood. Worked awesome. Need to pickup some new sheets of metal.
1A8056F6-DDB2-4C8F-B1BB-EE8D41F50F2D.jpeg 7005FF19-FBEC-47B3-9675-7200D9A9EC80.jpeg C92BD45A-37A7-49BE-90F5-EF8C6B9F6F98.jpeg BBB270A8-921D-4F63-AA9F-71DEEFF37883.jpeg 2F04895C-90A2-4020-8129-74F99CF996BA.jpeg
I’m waiting on trying to find a drivers side windshield pillar so, figured I’d start on the drivers side rocker then replace the door hinge pillar. I had to weld in patches on the inner rocker due to severe pitting & holes. Once that was done I tried rust remover gel on the inner rocker after wire wheeling it down. I’ll probably sand blast it before I permanently mount the rocker. Temporarily I screwed the rocker on so I can perfect the gaps later.
I removed the drivers side hinge pillar from the donor car and welded in a small patch. I’ll install this when I track down a windshield pillar.
EAFA8391-398F-4691-BF04-A0E60805B591.jpeg 3B097140-7F64-4A58-8152-3F785469C0CB.jpeg 3EE9234F-0820-4900-8B62-E55599575367.jpeg 57DB312B-F732-4613-9C0D-2F4AF75159A0.jpeg 842E7439-7800-446C-8B4E-EC3EB54F7C8D.jpeg 7DABE581-B2D4-4DB0-9EDF-4DDC1C367FA3.jpeg 5582534C-53B8-444A-BAF1-224DE32F9EED.jpeg 5AD50759-E67D-4EA5-9F9A-0565DBFBBEC9.jpeg 0764F983-0D2A-4AA0-94CE-DCFB031ED2B2.jpeg E33827D5-B94E-41AC-964A-E10586FAD27B.jpeg
Sorry for the delay, I’ve been making some slow but steady progress! Now for the dreaded windshield A-Pillars...
I went to a cool old junkyard and found a donor 69’ RR that had an unlucky date with my sawzall mid order to get a decent set of pillars. This is the passenger side.
960B6C34-BEF4-4A0C-89FC-CEA132DF8B52.jpeg ADF53C41-989E-4EBC-8744-F5EC26679766.jpeg E3FF5CDE-FE15-433B-8745-908C092E7CFE.jpeg 0E80A2EF-5B2A-4A84-A5C3-FE8BA3F68C89.jpeg 36EE3E09-9ABE-4848-8E9D-1A040FDA92D1.jpeg A8E2DB7B-97DD-4848-AF6D-0C65A2AD8EA0.jpeg 08C02238-420C-4E64-AB6B-398A9D56D1B5.jpeg 2E58BE00-922A-47EF-8A0E-B5B6806913E5.jpeg CEF2724A-58D9-4A72-98F8-F5B33AC89B41.jpeg 4523DAF5-118B-49A3-A7C8-8A611F6453D2.jpeg
Got the drivers side all wrapped up. Made a small patch on the firewall to cowl mating surface then, applied more weld through primer. Sandblasted both the upper and lower donor cowls then, welded the lower on. After that I epoxy primed both pieces and welded the upper cowl back on. Holy spot welds!!!!
Then, I was able to stick the donor front frame rails, aprons and core support. The frame rails fit perfectly and everything measures within spec according to the service manual.
FCDBAB0F-BFAD-48CD-99E1-F8EA03A79995.jpeg 6332ADFE-74C8-421E-AB2A-A302D82C5AE0.jpeg 7389AE9F-65EE-40BD-9DF5-A93CD5389DDE.jpeg 3224F678-3288-4BA3-8C2C-48421C9DA87D.jpeg ECA3FD35-D8C4-4F13-AF89-4CC1299B98E8.jpeg 3A5813BE-DD05-4BFF-831C-8E2B8A071AF9.jpeg 0176B0C3-D5A6-4557-8423-841F12C6944A.jpeg AE78E7D7-7412-47B1-9DE0-C9949A64FDFF.jpeg 246FB1F7-8F23-431F-9D14-7C1704B5787E.jpeg 42F49651-1710-4ED8-8E04-40236395841D.jpeg
Here is where the fun begins... I removed the rear quarters and cut everything back to get the car ready for sandblasting. Took a couple days off work and took the car to my buddy’s shop in order to sandblast / epoxy it.
It took a ton of time but, turned out decent. At least now I have a clean canvas to work on now
3A3120C3-ED2B-4A4C-8A63-7433976DF939.jpeg 9B2F62F5-9022-4144-A865-428340A47C35.jpeg 2417551D-E93E-49B3-AB56-F57A2C9D8F43.jpeg 56BBC5CF-84D1-4F2F-B4F4-8F9B9A3CF1B2.jpeg 6778C0E3-3FFE-433A-B02D-006113D1B7B3.jpeg AF97B26B-C255-4896-9FD4-1CDF082400B5.jpeg 6438FC40-26D0-477E-8AD8-7224DA0B12F8.jpeg 9F748CC1-045D-4ACA-998F-0E3A1F4EF724.jpeg
You’re doing some phenomenal work here, and you seem to know what you’re doing as well. I wish i had half your talent for body work. You will save yourself heaps doing this kind of thing yourself, and it will be one beautiful resto when you’re done. I’m enjoying following along here and appreciate your pics and posts. Well done.
Excellent work! Glad to see another young guy not afraid to crack a few beers, bust out the grinder/spotweld cutters/welder and tackle the seemingly impossible! I'll be following this one.
Thank you for the kind words! I’m no professional by any means, I’m just going full steam ahead with the little bit of experience I have. All of the info on this site helps greatly. I’m definitely excited to see it moving along, I just put in a big order to AMD for all of the metal I need. Thanks again!
Thank you! It’s definitely strange that not may of my peers are into older cars. They think I’m crazy for putting this much effort into a car in this condition LOL.
I know the feeling I'm 27 and "weird" or harsher names for believing that we should NOT LS swap the world.
Keep it up! We are the people to bring this hobby into the future. The last of a dying breed.
Keep it up! its awesome! Love watching what folks can do that are not scared and have the skills to do this work in our hobby. Especially in our garages......:thumbsup::thumbsup::drinks:
Great work!
I really enjoy watching how you are doing this work.
