Hemi vs L88
you've gotta wonder who was driving these things! #6 on the list is an 11.5 sec. car all day every day!
No way an unprepared pure stock 427 Camaro runs 11.5 on Polyglass tires. Now prepped like the super bee with a modern cam, ignition super valve job, modern ring pack, trick converter, yes. That entire old printed list is suspect. Look at what the pure stockers run now. And then see what it takes to get one to the top of the list. neither cheap, easy , or pure stock.
Whenever the debate over "best engine, as in most powerful engine, of the muscle car era" comes up I always say the 426 Hemi stock was one of the best, but the Hemi IS the best when modifications are allowed, and the more mods, the better it stood above the others.
Sure sounds like that bee driver was on and off the pedal quite a few times on the big end.
Hemi does well/better when tuning & mods are allowed
or when boost is added
or a professional driver
the 440-bbl HP was a great street killer
I've had a stock dual in-line Carter AFB 68 Hemi (427.5cid)
dyno-d as delivered pretty-much bone stock, just cleaned up a tad
(rebuilt as close to stock as possible, 0.010" over bore,
a little blueprinting, balanced with better tolerances
it delivered like IIRC 484hp @ the crank at like 6,200,
may have been 6,500 rpm
disclaimer;
don't mistake what I'm gonna' say next;
the LS6 454ci & off-road available GM performance LS7 454ci
more compression
both all Iron canted valve-d/rectangular port BBC's
great cylinder-heads, longer stroke, 4",
1/4" more than the 427 3.75" (or the 440 & 426 stroke)
LS6 rated at 425hp 475tq (11.25:1) at far less than it's red-line,
5200rpm or something, way under rated & ran on pump gas
& over 500hp @ 7,000rpm capable with very little tuning
& the LS7 465hp (11.25:1) @ like 5200rpm,
490ftlbs of torque @ like 5,200rpm
then near 8,000rpm was more the real red-line before nosing over
respectively out of the box near 600hp, 500+ tq on 97 oct. pump gas
in 1970-71 & using points/**** ignition systems
with an alum. Winters dual plane single 4bbl & Holley 850dp
even with all that, it was way underrated too
L88 427ci 425-430hp 12.5:1 20 made in 1967 - IIRC 80 or so more for 68 & 1969
with the snowflake Winters Alum. cylinder heads,
& Winters alum. dual plane 4bbl intake, Holley 850dp
were no slouches either, also way under rated, like 100hp underrated
they were not intended as a street engine,
they (dealers) were discouraged from selling too many,
to novices they preferred selling to known teams & competent racers
they were all rated "as lower respectively 425-430 HP",
for that very reasoning
people wanted the most advertised HP, they could get, bragging rights etc.
that was usually the 427ci 435hp Tri-power in the Corvette
the L88 made easily 100+ more
Ha! I'm building a 70 Stage1 right now. Guess I need two drivers to play with my Hemi. One for the Buick, and one for the Chevelle. Cheby is original LS5 block, but there are alot of those Winters casting marks above the block
In the 70s I was strictly MOPAR and everything else SUCKED...
Now I appreciate the better Brand X cars and engines...
Still, I think MOPAR has some of the best, and when I hit the streets in my 440 6bbl, I'm not "scared" given the car in the next lane being relatively at the same build level...
Once I get my stroker motor built, there's going to be a much shorter list of competitors I would worry about getting past me...
To me, there's no sense in investing that much money if I can't be bold in taking on any would be competition...
ZL1 copo is all stock from the dealer.When you take 170lbs off the front end and have the suspension mods they came with it's a winner! I love mopars but you've gotta be honest and give credit where it's due!
those motors were built for canam racing, GM just decided to let the general public have a taste!
watch some youtube ZL1 timing tower numbers, factory stock runs under 12 without even breathing hard on it!
You think those are "stock", no ah ah. Get involved in building a pure stock racecar. You'll be breathing hard, so will your wallet.
Take the cost difference between a COPO ZL! Camaro an a hemi Super Bee and modify the Bee with the extra money and see what happens?
Take the cost difference between a COPO ZL! Camaro an a hemi Super Bee and modify the Bee with the extra money and see what happens------ to your warranty!
fixed it for yah! yup 5/50,000 on the 69!
you guys just won't give in, mopar or nocar
believe me, I know what racing costs, did mine on the water in offshore, that requires a brief case,not a wallet!
How to make a small fortune racing offshore boats......
Start with a large fortune.
How to retire from aviation with a small fortune, start with a large one. Trust me.. and then a car restoration wiped me out! LOL
The Hemi was lifting because as was said they don't go faster then 11.50 or you will be disqualified. And as said they have no rollbar. That Bee will run easy 10's at close to 130 mph. He has to lift to stat slower then 11.50. Same for any car in the class that's faster then 11.50 as they will brake trying to stay no faster then 11.50. Ron
To me the COPO and ZL1 are not the same. The COPO cars I see in the Camaro's and Chevelle's are usually the 425 HP 427 L72 eng. Where as the ZL1 is just that a full blown race 427 eng in the Camaro. 12.5 comp with over .600 lift cam and aluminum heads and block. Its a race eng all the way as I believe Chevy built the ZL1 to counter the 68 Hemi Cuda's and Dart's. Even the L88 was a 12.5 comp eng as it was pretty nasty almost as bad as the ZL1. Both good engines and its cool that Chevy offered the ZL1 on the street but they were built to the hilt as they say. A fair comparison of a street Hemi with its 10.25 comp to a 427 would be compare it to the 427 L72 eng. The ZL1 sould be compared to the race Hemi that the racers built and used in the 68 Hemi Cuda and Dart for SS racing. These car shown here are in this modified class of Pure Stock. Course these cars are fined tuned and well prepared to the max as some will run in the 10's. There was no muscle cars that ran anywhere near the 10's or even 11's back in the day all stock. Myself I love the class as they are cool cars but they are not stock the way they came off the showroom floor as these guys do their homework and work hard to get their cars to run so good. And when they go to the Pure Stock race they cant run under 11.50 or they get disqualified. Ron
Stock eliminator is a whole nother bag o beans. My friends F/SA heads were $10K. Its quick .900 under, but not a record holder.
Magazine articles and "it should run this or that" are one thing, here's a real-world example: An old friend bought his '68 RR new. In the early 70's he re-did the bottom end with 12 to 1 pistons, and added what he always called a 'nascar' cam...(I never knew exactly what that meant) but I seem to remember him saying that was what was available at the time. Raced it as well as it being his only ride. No other changes except a wider early-70s tire. No other mods, stock exhaust and manifolds, nothing ported etc..and the car regularly ran mid-to-high 11s. Bench seat, column shifted, had carpet not the rubber mat, 3.91 8-3/4 rear. Still had it on the matching-color steel wheels with dog dishes when I rode around with him in '05-'06. Time slips with 11.70s from E-town still in the glovebox from the old days..by the time I knew him the dude was in his 70s and only cruised the car to work now and then(mostly because of the fuel 'cocktail' he had to mix up for it)...going for rides in that car was such a blast. Wasn't much on the street that was faster as the 'new' muscle cars weren't out yet..
