- 11:02 PM
- Apr 13, 2012
- Granite Bay CA
I meant to call the company today but I got sidetracked. They are 2 hours ahead and by 3:00 my time, they are headed home!
The status has not changed....I still need to evacuate the system then charge it with the refrigerant.
Today I went to the same place I went before and weighed the car.
I was expecting a slight weight loss. In this whole process, I replaced the iron WP housing with aluminum, the in dash HVAC unit is half the size and weight too. The add on weight was the A/C compressor and lines, the condensor and the fan shroud.
I was at 3940 before.
Somehow, today it weighed 4000 lbs even.
What the heck ? I absolutely thought that the worst would be that I broke even. The WP housing is an 8 lb difference. The dash unit should have accounted for a 20 lb loss at least. I had a full tank and a spare tire both times. This is a pisser.
Not that it changes anything, I just wonder how accurate their scales were last time.
Fuel in tank difference? Stuff in trunk (tire, tools?)Today I went to the same place I went before and weighed the car.
That red looks bitchin’ against the FBBO page background.It took YOU to motivate me to change it.
the ounces add up to many pounds quickly.That red looks bitchin’ against the FBBO page background.
