diesel_lv
1967 Coronet, 383 stroked to 496. 26" 2x1-1/4 aluminum core. Flowkooler water pump, robert shaw 160 n 185 thermostat. Serpentine pulley setup w reverse rotation water pump. W 2 electric fans 12" n 11", aluminum shroud w 10 additional 2" holes in it for highway airflow, it idles at 192° in 112° outside air temp w a/c running. But on the highway at 60+ it gets to 220 on flat n level. Changed to Derale 18" non flex reverse rotation direct mount fan w factory shroud. Idles at 228 w a/c on in 114° temps. Haven't gotten it on the road yet to see if it will be cooler at highway speeds. Any rpm above 1400 n trailing edge of fan blade nicks a/c compression rivets. I have a 1" spacer. The fan is perfectly 1/2 in 1/2 out. If I move it 1/4" forward, it will hit radiator lower tank. Definitely not happy w idle temps compared to electric. And the fan touching the a/c compressor is definitely no-go. Any suggestions? Lightly bend traing edge of fan at area where it hits a/c compressor? Before someone asks timing, a/f ratio etc. Everything is dialed in. "Only" issue is temp at idle w mechanical fan and touching a/c compressor. Thank you
