I am so distraught...CURSED!!!
 I put the clutch fan back on today.
I put the clutch fan back on today. Keep in mind that this is the 2nd time I have personally done this.
Last time it worked better than the dual 12" fans and shroud. No "220 plus degree" temps. I thought I'd like it to be a little cooler sitting still at idle, but it was only in the 190s-200
So today I drove a few blocks, about 2 or 3 minutes to the backroad highway. Hit the back highway, 55 MPH limit, and that's what I drove. AC on, temp in the high 180s-low 190s. I don't think it got hotter than 192.
Stop and go through a few lights, still good, 187-192. Jump up on the highway, 72 MPH and 3,600 RPMs...
 ALL GOOD!?!
The 421GOAT was rollin! and I was chillin' AC still on BLAST...Max temp was 197 and that was the same route that took the temps
over 220 degrees yesterday. I'm good I'm thinking, I'll mod the factory shroud and it will maybe work a little better, but staying under 200 degrees is GREAT.
DAMN ELECTRIC FANS!!!
THEN I GET HOME, AND I SEE THE ½" OF SPACE BETWEEN THE FAN CLUTCH FACE AND ALUMINUM RADIATOR WASN'T A BIG ENOUGH SPACE!!
The face of the fan clutch somehow closed the ½" gap and chewed its way into my "new" aluminum radiator...coolant spraying everywhere, dripping off the hood...
So I have torn up my new Cold Case radiator, I've paid about $350 for
each of the electric fan and shroud assemblies, another $100 for the Dakota Digital PAC-2800BT fan control module, and about another $60 for 2 circuit breakers and 2 relays.
Now I'm looking for TWO 17" FLEX FANS because I have serious doubts about the 17" electric fan on my Roadrunner, and I only have 3" of space between the radiator and the Wraptor pulleys.
Looks like almost ALL 17" FLEX FANS ARE OUT OF STOCK....EVERYWHERE!
I'm going to put the factory radiator in the GTO tomorrow and see how much space I have between the fan clutch face and the radiator. If I don't have at least an inch of space, I can't run the clutch fan.
TWO ELECTRIC FAN AND SHROUD KITS
TWO CIRCUIT BREAKERS AND RELAYS
ONE DAKOTA DIGITAL FAN MODULE
ONE COLD CASE RADIATOR
AT LEAST 4 DAYS UNDER THE HOOD...
and what do I get??
One torn up radiator, 2 fan and shroud kits to return. A Dakota Digital fan control module that I don't need, and the relays and circuit breakers I can't use.
AND...
What is going to happen with the 17" setup on my Roadrunner??
I am going to line up a 17" (or 18" whatever the largest diameter will fit) flex fan for the Roadrunner, in case I have problems with high temp cooling system issues.
