Have you tried a couple more degrees of advance?
What are you running for heads?
I finally gave in to the dark side. Purchased a Holley Sniper EFI for my GTX. I've been having a weird lean pop at mid-low rpm that I just cannot tune out on my Edelbrock AVS carb. Said "F' it and bought it.
I already have the Holley Sniper EFI gas tank with 255 Walbro pump and an o2 sensor installed so it should make for an easy swap. I went with the EFI 4150 550-516 unit. 800cfm and good to 650 hp. Has a built in pressure regulator and is what sold me on it.
Going to document my install as I go. I'm curious as to how my throttle and kickdown stud fit. I am assuming I'll have to tweak it.
I'm assuming you have been working on this since Dec. and hopefully you have been successful. I'm in the middle of installing this same Holley EFI on my 440. What I'd like to ask you is where did you end up putting the temp. probe? I have Digital gauges and the only spot I can see for a mounting location already has the probe in it.
Thanks Mike, the water pump location is where I put the probe for the digital gauges. Finding a suitable location for both the EFI and digital is a real challenge. Can I ask where you got the coupler for the radiator hose?I have my efi probe in the WP, I also bought a coupler that goes in your radiator hose that has a port for my analog.
This isnt the exact one, I couldn't pay $55 but there are others out there a lot cheaper.Thanks Mike, the water pump location is where I put the probe for the digital gauges. Finding a suitable location for both the EFI and digital is a real challenge. Can I ask where you got the coupler for the radiator hose?
Thanks for the info. How does that work out for you, do you get a correct reading for temps and the EFI? [/QUOTE]This isnt the exact one, I couldn't pay $55 but there are others out there a lot cheaper.
https://www.summitracing.com/parts/...kOKetYKFvcz0qx0PThaTEPUl1rWpDIVRoC8uEQAvD_BwE
[/QUOTE]Thanks for the info. How does that work out for you, do you get a correct reading for temps and the EFI?
That looks like something interesting, where did you come across this?
Yah I see that, 17.4 mm, thanks for the link even so. This may just help if it can be adapted, thanks for the help.https://www.napaonline.com/en/p/NDP...6478877959&adgroup_id=79272987338&adtype=pla&
Thing is who ever wrote the page didn't give usable specs so I have no idea what the thread size is.... I've seen various sizes of similar fittings in the past but who knows if they are still available...
