beanhead
Easily Offensive
When you said,
It seems pretty cut-n-dried to me....the issue is with the new distributor and/or any wiring changes you may have made to accommodate it. If you didn't do anything to any wiring and just swapped the distributor, either it's faulty or it's not set up right.
....does that mean you tried it again and the engine still won't fire? Or does it mean you're not planning on using it going forward, so you didn't try it to rule out the MSD?.... old distributor is a no go
