- 10:45 PM
- Aug 29, 2019
- Jarvis, Ontario
Yes I am going to use my old carb for break in. I will pop the top off and fill the bowls first.Looking great. Your rotor is correct because both #1 lobes are on base circle (firing). make sure all vacuum lines are good, fill the bowls, lighter up!
This is because those paper gaskets were not designed to be used with that motor.I needed a little help to get the intake bolts aligned. It was pretty tight but I got it snugged down. I will be removing the bolts one by one to add the brackets later.
View attachment 1120512 View attachment 1120513
I used the blocked valley pan gasket. I previously removed the heat riser. Also put rtv on the front and back. Hopefully leak free.Metal gasket with block off for the exhaust exchange at Jeg's. Need RVT at back and front of motor gasket.
Looks like Wile E Coyote is involved!!! Nice work!I needed a little help to get the intake bolts aligned. It was pretty tight but I got it snugged down. I will be removing the bolts one by one to add the brackets later.
Yes I restored my heat riser also. They say I don't need it in Fl. But here guy's say their car's run cold even in hot climates. Figured the guys that built the motor's knew it need it for first start up so I restored mine.
Don't think blocking off the exhaust through the intake will make that much difference do to the cooling fluids are still running through the motor and will heat up the block that way also.
