Coronet67guy
I found an old similar thread but figured best to start a new one. I'm currently experiencing no oil pressure on a manual gauge in my 74 Charger SE. I'll cross my fingers and have an oil pump put on next week, but need to prepare myself for the more likely motor failure. I'll have someone else doing the rebuild but will be able to supply my own parts. I would probably want to do new bearings, pistons, rods, lifters, possibly cam, etc. Curious as to any good kits or if it's best to buy it all separate. This is not a drag car, so cruising capability is a must.
Car has duel plane intake, TTI headers, 3.23 posi, rebuilt tranny with just over stock new converter, and more. Not sure what hp it's putting out but if I did a stroker kit I would probably need to keep it on the mild side, like the 451. The car is still running stock 14 inch tires. I think I would need to change that just to keep them on the ground. All thoughts and advice are appreciated. I'll update Wednesday after the oil pump install.
