- 10:33 PM
- Sep 5, 2017
- 6720 Cuff Road Jackson, MI 49201
If the motor work goes without too many issues should make it to Carlisle in July. If not, it wont be for lack of trying.
Very nice work Builderguy. Just curious, where did you find the quater glass seal with the chrome trim. The one that is curved and seals against the body not the straight one that seals the the door window. My replacement was all rubber no trim so it is not correct.Ran into a slight snag. Installed the new cam bearings and the new cam but had little trouble with #5 bearing. It seemed a little too tight. Put the cam in and again #5 was a little tight. You can spin the cam by hand but there is more resistance than would be expected. Solution: "bluing and scraping" where you use machinist's blue on the ID of the cam bearing to see just where there insufficient clearance is and then you literally "scrape" (with a bearing scraper") this area down. Reapply the bluing and reinstall the cam to check if you took enough off. Way to much of a pain in the *** for me, so I sprung for another set of cam bearings to see if that would solve the problem. If not, I am only out $60 and can go back to bluing and scraping as needed on this new set.
Switched back to my shop and put in the 1/4 glass and then set the window gaps.
Only took a few minor adjustments to get the window to seal properly. Next, the wife and I installed the drip rail chrome strips using a taped up dead blow. Sorry, only took a pic of the right side.
View attachment 1127170 View attachment 1127171
Got the rear sway bar bolted in and also took time the make sure all the E-Brake cables reached and worked.
Yes that is what I am finding I will assemble mine with the black ones and change them out later.I got those "Top Cat Whiskers" a few months ago from Detroit Muscle Technologies. They are out of stock as of a couple weeks ago. Need another set for my other 73 RR. I called Quirey Quality Design (QQD) for an update of when they would be back in stock. I was told that QQD as working on this as the makers stopped production. QQD is in the process of taking over this business but they wont be available until late this year if all goes well but probably not until spring of next year.
With all the parts I lost during my project I always find them exactly where I left them, you know the spot you said to yourself " I'll put it here where I know where it is at" LOLK-frame got sprayed today. It looks like gloss in the photo but it will dry down to the semi-gloss that it is. You would think in a small garage it would be hard to lose a piece but I lost the starter splash guard. I blasted it and sealed it but now I can't find it anywhere. %$@#*$%$
